copper oil lines to mains
Ken C.
08-19-2004 20:09:41
The metal oil lines going to the main bearings on my 52 G are in bad shape, one broken, the other rusted. I made new ones out of copper tubing, will the copper do just as good as the metal, or is there any problems with this. Also any ideas on getting to those flywheel bolts. put new ones in but can't get to them to tighten, you should see that wrench i bent in all directions and still can't get to them. Thanks for any help, Ken.
Larry806
08-19-2004 20:28:20
 Re: copper oil lines to mains in reply to Ken C., 08-19-2004 20:09:41
There isn't any problem with copper oil lines as long as they aren't kinked anywhere. The flywheel bolts need a JD flywheel wrench I've never found anything else that will do it right
