JD 4000 OIL LEAKS OUT JUST UNDER THE STEERING WHEE
RALPHR
08-19-2004 14:19:52
HELP I HAVE A JD 4000 THAT I AM WORKING ON AND I HAVE A LEAK (HYDROLIC OIL?) JUST UNDER THE STEERING WHEEL. IT SEAMS TO BE COMMING UP THE COLLUMN ANY IDEAS?
msb
08-19-2004 16:39:56
 Re: JD 4000 OIL LEAKS OUT JUST UNDER THE STEERING in reply to RALPHR, 08-19-2004 14:19:52
Yep, Its coming around an o ring on the steering shaft.and its the last thing to come apart when overhauling the steering valve.If it is just a very small seep they you may get lucky and pull the steering wheel and remove the snap ring and then replace the seal under the washer,but I seriously doubt you will be so lucky.
Best thing to do is remove the complete valve and take it to your Deere dealer.To do it right,it takes special tools and some special knowledge to rebuild those things.
david val
08-20-2004 04:26:35
 Re: JD 4000 OIL LEAKS OUT JUST UNDER THE STEERING in reply to msb, 08-19-2004 16:39:56
first thing to do is as mentioned, to remove the steering wheel and replace the shaft seal kit. if this doesn't help for long then going into the steering valve unit is rquired.
david
