1956 /620 blows power steering fluid out
DAVID LEE
08-19-2004 09:56:48
I recently purchased a 620. I am in the process of overhauling the engine. But the power steering unit blows the oil out of the breather cap.
more so when the tractor got up to temp. Any thought would be appreciated.
Clooney
08-19-2004 10:21:34
 Re: 1956 /620 blows power steering fluid out in reply to DAVID LEE, 08-19-2004 09:56:48
David, The usual reason those 2-cylinder P/S systems blow out oil is it is sucking air into the system from somewhere.. The usual place is the rear P/S pump seal.. But about any slight pin hole in the suction fittings or lines can allow air to be sucked into the system..
I have even seen those systems suck air at the main spindle �O� rings when sitting for extended periods..
Incorrect fluid can add to the aeration issue but usually doesn�t cause an air issue by itself..
Probably the thing to do is pull the hood nose grille assembly & go over all the lines for being loose or leaking.. Then look for obvious signs of a place air can enter.. If nothing obvious found probably pull the pump & reseal it.. If you have any leaks in the lower spindle area that should be resealed also..
Any questions just post back..
[email protected]
