2640 not starting after getting hot
Cory
08-19-2004 09:36:21
Just bought this tractor. After using it for a couple hours or until it gets good and warm (not overheated, just normal operating temp.) it won"t restart if you shut it off. I shut it down to remoe the bush hog and go get a drink, came back about 5 mins and it wouldn"t start. It cranked fine, but a little slow, unless you moved the steering wheel back and forth!!?? But no start. I let it set about a half hour to an hour and it fired right over. Has done this three times in last two days. Any ideas? I was thinking maybe a bad wire leading to glow plug relay? (does it have a glow plug relay?) My Dad seems to think starter, it drags a little like it maybe going out. I hav seen this in cars, but not tractors, could it be?
Thanks
Cory
P.S. it is a 79 model JD 2640 with power steering.
Cory
08-24-2004 06:15:09
 Re: 2640 not starting after getting hot in reply to Cory, 08-19-2004 09:36:21
I do beleive it is the starter. I has always started slow( cranked slow) but I assumed that was normal. Checked out a friends JD and it cranks very fast. WHen it is hot it cranks even slower, I bet it is the starter. Right now I don"t use it much so I can get by for a week or two before a rebuild. Thanks for replys
Cory
Dieselrider
08-19-2004 19:23:50
You may want to check your fuel filter too. I have one of these tractors and they usually fire up so fast the starter doesn't need to turn it much before it's running. Also make sure your fuel shut off is returning all the way when you release it. Could be a weak spring and you're actually starving the thing. Good luck and let us know how you make out.
WTW
08-19-2004 11:18:21
Cory, Could be that tractor is not cranking fast enough or it could be that you have lost your fuel delivery when engine is hot. If your problem is fuel delivery, engine exhaust will not show any smoke emitting from it when cranking. If tractor is smoking white smoke from exhaust and engine fails to start it is getting fuel. Problem could be that engine is not cranking fast enough. I doubt this if engine will crank at a decent speed when hot it should start even if it is a little slower. If no smoke the fuel delivery valve in injection pump may be leaking and when engine is warm, fuel injection pump gets warm, fuel gets warm and thinner, leaking fuel delivery valve in injection pump leaks more than when fuel is at a lesser temperature causing low or no fuel delivery. If you suspect that it is fuel give engine a shot of starting fluid and see if it takes off and runs. The starting fluid may cause the engine to start and run long and fast enough to get ahead of the leaking delivery valve. Just sounds like your problem could be fuel Check it out and let us know what you find. Good Luck, Dave W.
Mike M
08-19-2004 10:09:43
If you think that starter may be dragging then by all means get it off and get it checked out as if it is dragging it is a cheap fix if caught early but expensive if it burns up inside.
My uncle had a 2640 that would not start if cold guessing 32 F. He tried everything had the starter redone ,maybe even looked at twice by the same shop. He told me about it I came over and it seemed to turn over but just not fast enough. I took the starter off took it to a local small shop told them the history he said everything tested ok,but the armature bars looked loose or something. Anyhow put a rebuilt armature in it and it spins alot better and starts better. I guess if there is a moral to this story it is that just because it was rebuilt and looked rebuilt it still wasn't right.Follow your instincts on the starter first it just may be all of it.
