JD 420 PTO Lever Detent
texczech
08-19-2004 08:25:36
I have this JD 420 that doesn't feel like the PTO lever when engaged, snaps in or has any detent. In fact, sometimes the lever jumps out when using the PTO shredder, which disengages the shredder. If it has a detent system, where would I look, and how hard is it to repair? Thanks.
Henry J
08-19-2004 14:43:05
 Re: JD 420 PTO Lever Detent in reply to texczech, 08-19-2004 08:25:36
tex
The shaft that goes thru the trans will have a detent ball that is pushed towards the detent holes on the pto shifting fork by a spring. I wouldn,t know why your ball is not engaging the detents.
I can only speak form experience with the Wide, but to get to that mess physically I think you will have to split the tractor and take the top shaft and gears out of the trans - whick I think might mean pulling the rear cover on the trans also since there might be a coupling pinned to the input shaft on the differential side of the trans case.
You might look down about half way on the side of the trans the lever is on. There should be a big nut looking affair there. Inside is the spring that is supposed to be pushing the detent ball into the detents. Remove the nut and pull it out gently - the spring should still be in it - look in the hole and if you are lucky the ball may still be there to pull out with a magnet - see if you can see detents as you move the shifting lever. If so, I would think that you could sneak a new ball and spring on there by using heavy grease to hold it together for the insert and tighten her back up.
Maybe the spring got weak or broke.
You may already have the old ball rolling around in the bottom of your trans, whick I think shouldn't hurt anything.
Have fun in there.
CRUSADER
08-19-2004 09:26:57
Hey texczech,
Where are you located at? I'm currently living in New Mexico, but originally from Texas. Not sure about the 420 because I've done very little with them. You may want to check the linkage. I know that the adjustments on a 630 for the PTO are not hard to do, but sometimes can be a PITA to get to. The owners manual if you have access to one should be of some help.
Jim
