JD 430T
TxTrac
02-02-2004 22:11:27
What does the T stamped in the ID tag identify?
Clooney
02-03-2004 02:54:25
 Re: JD 430T in reply to TxTrac, 02-02-2004 22:11:27
TxTrac, that "T" stands for TRICYCLE.. BUT, it could still have a wide front end under it.. Not all 40T, 420T or 430T had a narrow [tricycle] front end but they still used the T designation..
[email protected]
TxTrac
02-03-2004 05:07:02
 Re: Re: JD 430T in reply to Clooney , 02-03-2004 02:54:25
I had that in mind. Was the wide front on this 430T changed after it was built?
I'm also interested in a 420WL and knowing the meaning of the WL.
Wayne in Tn.
02-03-2004 06:27:34
 Re: Re: Re: JD 430T in reply to TxTrac, 02-03-2004 05:07:02
The 'W' means row-crop or wide front. The 'L' means an LP model or propane gas. I had a TL that was tricycle-propane. I have never seen a WL tag. Usually the L was stamped by hand while the tractor was in the assembly line, sometimes the L will be crooked or leaning, just depending on the person who stamped it, maybe on a Monday, with a hangover...Ha...
buickanddeere
02-03-2004 06:25:00
Rowcrop Utility with a LP engine. The rowcrop utility was another wide front but different from the utility and standard. Final drives are inboard rather than outboard but the front spindles are a wee bit tall. The tractor faces uphill with the usual 12-28/13.6x28 rear. Near level with 10-34/11.2x34/12.4x34 .
TxTrac
02-03-2004 15:44:35
 Re: Re: Re: Re: JD 430T in reply to buickanddeere , 02-03-2004 06:25:00
This all gets a wee bit confusing especially to a AC {Bleeding Orange} person. The only JD I ever had was a 112 lawn tractor. I'm interested in all pre 70 tractors of all colors. I ran across the J-Deeres on a used tractor lot in NE Texas and the owner asked me what the T and the WL stood for? I had no clue but told him I would try to find out. I will pass on what I have learned from you {bleeding green} folks and we hopefully all be more knowledgeable for it. The 430C he has was obvious. It had no wheels or tires just crawler tracks. The 420WL was gasoline which may have been converted. I find this to be real common with older tractors. I have seen lots of AC-B models with SN's prior to 1940 with starters and chevy steering boxes. We must make do when we need to.
