Help with an M
weblvr
08-18-2004 13:53:10
Here I am again, begging for help. I feel like a welfare recipient since I probably will never be able to contribute much to this board. At least I admit it....Todays' problem is how to remove the hydraulic pump from my model "M"? There are a number of capscrews that I removed as well as the hydraulic lines. I beat and pried on the pump (gently) to no avail; that sucker just won't move. Ideas? Again, thanks in advance. Gary north of Spokane.
JDM Guy
08-18-2004 16:30:52
 Re: Help with an M in reply to weblvr, 08-18-2004 13:53:10
When you take that thing off be very gentle because if you mess it up then its gunna get nasty money wise. When I took mine off I did what vrickster did with the crow bar. My "M" is a 1951 and from what I've worked on there was two different pumps between the early and late M's. I don't know what year M yours is so I don't know what pump you have. Have a great day.
vrickster
08-18-2004 15:27:21
There are 3 screws that hold the pump on, all 3 are allen head. Viewed from the front of the tractor the screws are approximately at 12, 2, and 7 o"clock. The other allen screws hold the pump together and do not need to be removed. Sometimes the pump drive shaft gets stuck in the coupling on the end of the cam. Once the screws are removed I would do some careful but deliberate prying between the pump and the engine front gear cover. Try a crow bar somewhere around 9 o"clock on the pump.
weblvr
08-20-2004 08:30:52
 Re: Help with an M in reply to vrickster, 08-18-2004 15:27:21
It worked! The operative words here were, "careful but deliberate prying." Many thanks to you guys; ya saved me again!
