Deere
Goodwrench
08-18-2004 13:33:26
Is there an ability to convert a late "A" ("51) to live hydraulics via pump/governor mechanism used on the "60"?
Mike M
08-18-2004 17:50:59
 Re: Deere in reply to Goodwrench, 08-18-2004 13:33:26
I think you would have to replace the governor housing with the one from a 60 I think a local fellow did this so it may be possible. The late AR models used that same style of hyd. pump also and that housing should fit for sure.
Clooney
08-18-2004 17:30:38
Goodwrench, you ask...
Quote: "Is there an ability to convert a late "A" ("51) to live hydraulics via pump/governor mechanism used on the "60"?".....
--I won't say positively no but if it's possible it sure won't be easy as it won�t just be a bolt-on.. There was an aftermarket Live Hydraulic pump available that went between the governor & mag/distributor & that added live hydraulics to the �A�.. You still won�t have the hydraulic power of the numbered series though.. I see those �Live� pumps from time to time at swap meets & on Ebay..
[email protected]
