A3367R head question, John Deere A
Craig S
08-18-2004 11:59:10
Would a A3367R head for a John Deere A fit on a 6-1 power block that is on a 39 John Deere A?? Usually the 40-46 JD A would take a A2325R head, which works on a 39 with a 6-1 power block. Just wondering if the head from a 48 JD A would work. Thanks.
Big Jugs
08-18-2004 19:55:12
 Re: A3367R head question, John Deere A in reply to Craig S, 08-18-2004 11:59:10
it will fit. the 39 would've had a flat head. The no. 1 power block will fit the unstyled, early styled, through 46. The head from a newer tractor will need to be used. On the later ones, the head was cast a little bit thicker, thats all.
Craig S
08-19-2004 06:28:46
 Re: A3367R head question, John Deere A in reply to Big Jugs , 08-18-2004 19:55:12
So, what I would have to do is either shave the A3367R head or get longer pushrods for the valves? Would the pushrods from a 48 JD A work for this purpose???
