4040 water pump rebuild
Bill R
08-18-2004 06:16:44
Rebuilding a 4040 water pump, pressed off the fan hub,now which way will the shaft/bearing come out
of the cast housing? Appears it could go out either way? Thought wiser to ask someone with knowledge before I put too much to it and crack the housing. Will added heat help? Anything else on the assembly I should know?
Thanks, Bill
RJ-AZ
08-19-2004 20:58:54
 Re: 4040 water pump rebuild in reply to Bill R, 08-18-2004 06:16:44
I always push the bearing out the back, Impeller seal and all. Some times holding it in the crook of your arm and hitting the shaft will break it loose and not damage the housing.
