4010 front PTO
KIP
08-17-2004 11:00:17
What implements were made to run off the front PTO on 4010 and 4020? Seems like I remember seeing a belly sickle mower on one.
JDBert
08-17-2004 11:57:51
 Re: 4010 front PTO in reply to KIP, 08-17-2004 11:00:17
We had a hiniker snowblower that was front mounted and used the front PTO. Otherwise for actual JD implements I know there was a mid mount sickle mower.
msb
08-17-2004 19:23:21
 Re: 4010 front PTO in reply to JDBert, 08-17-2004 11:57:51
Called a side mount mower the model number was 10.Kind of a bear to put on but nice to use after it was on.You could unhook the drive but still leave it on and still use the rear PTO to do things like rake hay or run a baler etc.The front pto was 1,000 rpm only as I recall.Seems like there was other applications that used the front PTO but its been a while.Some farmers used it to drive a spray pump. Don't know why someone didn't think to hook an air compressor to the darned thing.Maybe I was the only one to have an air driven impact wrench back in those days.lol,bob
KIP
08-17-2004 20:03:21
 Re: 4010 front PTO in reply to msb, 08-17-2004 19:23:21
Yes, it�s 1000 rpm only. I don�t think ours ever had the cover off. Never really thought about a compressor, but that�s a fine idea.
Gerald J.
08-18-2004 21:03:00
 Re: Speed depends in reply to KIP, 08-17-2004 20:03:21
The 4010 and 4020 are made differently.
On the 4010 the front and rear PTO shafts run the same speed, shifted by the rod inside the rear end of the shaft pushed or not pushed by the bolt on spline.
On the 4020 the PTO shaft insert contacts the right drive for its speed while the front PTO shaft stays at 1000 RPM.
I've confirmed this in the 4020 operator's manual and the shop manual that cover's the 4010 and the early 4020 that I have.
Gerald J.
