4010 lift squeal
txblu
08-17-2004 09:20:31
3pt position spool (sounds like) squeals (oscillates) unless the 3 pt either has a load on it (weight) or is in the full up stow position (which may present a load to the hydraulics).
Suggestions welcomed. Fluid is clean and full. Started this recently.
Thanks
Mark
HTR
08-17-2004 19:32:46
 Re: 4010 lift squeal in reply to txblu, 08-17-2004 09:20:31
You may have a combination of small problems. The tractor does not use spool valves: they use poppet valves. The valves could be out of adjustment, or have a piece of junk in them, but not likely. If the tractor is newer than the first year, there is a thermal relief valve in the top of the cover, on the back of the rockshaft valve housing. I think it takes a one half inch wrench to take it out. The valve looks like a float neddle in carburetor with a small heavy spring and shims. If the neddle has a ring worn around it, it is leaking, and will cause a squeal.
Another place to look is the rockshaft piston. Take the back cover off of the rockshaft housing, six bolts. Raise the arms (by hand) and drop them will usually pop the piston out. It has an Oring and two back up washers.
It shouldn't load the engine, or hurt anything for the arms to come top. That is the way the hydraulics work, when the arm come all the way to the top, the pump goes out of stroke.
txblu
08-18-2004 06:49:44
 Re: 4010 lift squeal in reply to HTR, 08-17-2004 19:32:46
Thanks HSB.
Boy this forum moves fast. Lots of posts since I add this one yesterday.
Will investigate what you said.
Thanks again for your help,
Mark
msb
08-17-2004 19:41:01
Remove the shield under the right side of the seat to get a better idea if the thermal relief valve is the problem.If it is,sometimes you can take a hammer and punch and tap on the valve to give it a new seat or put a heavier spring on it.I have on occasion shimmed the springs up a bit.
txblu
08-18-2004 06:48:33
 Re: 4010 lift squeal in reply to msb, 08-17-2004 19:41:01
Will try that
Thanks msb.
Mark
