70 clutch pulley
JohnF2020
08-17-2004 01:11:13
Well i got my clutch pulley pins etc on the 70 repaired without disastrous results so i've put it all back together but there is about 1/2 inch freeplay movement of the pulley on the shaft.Should there be a floating disk between the pulley centre face and the outer gear/disc facing.
E.G. BEHIND the outer gear disc.If there should be,i'ts missing.
Clooney
08-17-2004 03:23:39
 Re: 70 clutch pulley in reply to JohnF2020, 08-17-2004 01:11:13
third party image
John, 1/2" of lateral movement is too much, it should have some movement but that is too much..
You need to ALWAYS have a lined facing next to a steel facing.. If you remember that you can't go wrong [see picture]..
If after making sure all the clutch disks are there & in the correct place your excess movement could be misadjusted fork stop bolts [late clutch] or incorrect apply pin shims [early clutch]..
That pulley does need some lateral movement when disengaged or it won�t release..
Any questions just post back..
[email protected]
JohnF2020
08-17-2004 04:53:51
 Re: 70 clutch pulley in reply to Clooney , 08-17-2004 03:23:39
Clooney-I'm missing the first floating disc/the one between the pulley anf the outer gear.
thanks for the pic.It was very useful.
Thanks,
John.
Clooney
08-17-2004 05:32:41
 Re: 70 clutch pulley in reply to JohnF2020, 08-17-2004 04:53:51
You"re welcome John....
Clooney
JohnF2020
08-17-2004 07:54:46
 Re: 70 clutch pulley in reply to Clooney, 08-17-2004 05:32:41
Clooney---do you have the jd part number for the floating disc in the clutch.Being here in Ireland i still have not received my parts book so my local dealer cant get it for me---is it used in anything else?
Thanks,
John
JohnF2020
08-17-2004 06:15:55
Clooney--would you have a diagram of the entire induction system of the 70 diesel..Is there a seal between the induction manifold pipe and the pipe coming from the air filter..it appears to be in 2 pieces.I've got oil leaking from here and running back down the manifold.I think it may be from the pony exhaust.
Clooney
08-17-2004 09:35:17
 Re: 70 clutch pulley in reply to JohnF2020 , 08-17-2004 06:15:55
JohnF2020, send me an E-Mail,, put [70D intake] in the subject line & I will try to send a decent picture of the intake tract..
[email protected]
