JD 2555 PTO Clutch Slipping
Gerard
08-16-2004 22:22:17
Recently replaced trans pump cracked line and pto clutches, ran unit ok for about 20 hrs using hydraulics for bucket use only, tried using unit for shredding next but pto clutches seems to be slipping. Checked trans pressure at 150 psi and pto brake pres also 150 psi but pto clutch pressure was only 100 psi. Is there an adjustment to bring clutch pressure up to 150 or is there a possible fault in the trans cover area? Help! Help!
david val
08-17-2004 01:57:15
 Re: JD 2555 PTO Clutch Slipping in reply to Gerard, 08-16-2004 22:22:17
low pto clutch pressure indicates a leak. there is no pressure adjstment for the pto clutch pressure.
to isolate the problem remove the shift lever cover.
make sure the tubes for the pto cluth and brake are there and their placement matches the relevant holes in the cover (there are 4 holes in the cover.only two of them are pto related. i don,t remember which ones i think it's the two right side ones).
with an air gun, blow shop air into the tubes (make sure the connection is sealed), there shuold be a small flow of air bubbles through the oil. if there is a fast flow of air through the oil or air noise above oil level you have a leak and the tractor should be split again. if you have high lo shift unit, the oil pressure to the pto components passes through the hi lo housing which may present more leakage points but ait pressure test resutls are the same. if there is very little leak in the test, it's possible the pto clutch tube was not in it's right hole or there is a leak in the valve block.
david
