70 Dis now charging
Dan in Ohio
08-16-2004 17:51:47
I went through the check list you provided and still was not charging, so I took the generator apart and cleaned the brushes, springs. Now it charges. When I install a new wiring harness hopefully the fuel gage will also work. Thanks for all your help John T. and Clooney.
Clooney
08-17-2004 06:13:50
 Re: 70 Dis now charging in reply to Dan in Ohio, 08-16-2004 17:51:47
Dan, you"re welcome..
When those generators won�t charge [or motor] usually a good commuator & brush cleaning is all that�s required..
On your fuel gage problem--- Those late numbered series fuel gages are prone to problems, especially if full battery power was EVER sent to the tank sender.. They also don�t like to work at reversed polarity.. When you get the fuel gauge all wired per the print [pay particular attention to the fuel gage switch wiring & the wire that goes forward to the voltage regulator],, if it still doesn�t work make sure the fuel tank sender unit has a GOOD CLEAN ground to the tractor chassis [the most common fuel tank gauge reading problem is a poor tank sender unit ground]..
Those diesel fuel gage components are getting real hard to come by so post back or give me an E-Mail before trying to test the parts so I can guide you through the test procedure.. You don�t want to take any chances on frying a gauge part due to the testing procedure used..
[email protected]
John T
08-16-2004 21:25:27
Congratulations Dan, glad we could help and you are most welcome. I had many through the years that wouldnt charge and all I did was clean n lube the brush hold down spring assemblys and they worked fine, so thats why I advise to check the brushes n hold down springs etc AFTER the troubleshooting verifies its NOT a Voltage Regulator problem.
There"s no guarantee the fuel gauge will now work, they often have sender or ground problems. Once you get her all wired post back or e mail me at [email protected] and I will guide you through how to troubleshoot that also. Basically, the gauge has to have voltage present on its input, and then the sender unit provides the ground return current (to cause gauge deflection) path via its varisable resistor and then to tank case ground. You have to first verify the gauge has voltage to it (usually via the switch when ON) and then if you dead ground its output (terminal or wire to sender) it should deflect. If that passes (gauge deflects when output grounded) but she dont work via the tanks sender unit, the sender is bad/open,,,,, ,,, or its not well grounded to the tank,,,,, ,, or the tanks not well grounded to the tractor.
Post back or e mail if the gauge dont work for more detailed troubleshooting and again, congratulations, glad we could help, and thanks for the update.
Best wishes n may God Bless ya n the others here.
John T Nordhoff in Indiana [email protected]
