Clooney on the Electric Motor
Henry J
08-16-2004 13:42:44
Clooney
John T gave me some info that I am sure will do the job on hook up this motor on a trial and error basis.
A while back you said you may have a book that would give the hook up, so here is the stuff off the data plate:
Fasco Industries Inc
Eldon MO DIV
Type U 51
V230 HZ60 PH1 ROT ->
HP 1/6 AO
AMP 3.2 NO 7151-3547
RPM 900 (2-SPD) CPN 1468-120
Orange - Common
Black - High
Black - High
Red - low
How would you hook this up to the two hots on a 220 to get each speed?
Thanx
Henry J
08-17-2004 09:04:00
 Re: Clooney on the Electric Motor in reply to Henry J, 08-16-2004 13:42:44
Thanks all, if that don't do it lets give up. Don't worry about me getting shocked, 220 gives me the heebie jeebies just thinking about it.
Clooney
08-17-2004 09:51:22
 Re: Clooney on the Electric Motor in reply to Henry J, 08-17-2004 09:04:00
Henry..
Quote: "Don"t worry about me getting shocked, 220 gives me the heebie jeebies just thinking about it".....
--If you get in the habit of keeping one hand in your pocket when working around uncertain power connections that will take some of problem away.. While you could still get a pretty good jolt it probably won�t kill you.. The biggest problem comes when you use both hands & the current passes through both arms & your heart.. At least your feet should be somewhat insulated due to your shoes [you don�t work barefoot do you?].. Also use the BACK of your hand to touch the wire first as any power into your hand will cause the muscles to contact & pull you hand away instead of grabbing on if you touch it with the front of your hand..
Clooney
Clooney
08-16-2004 18:53:22
Henry J, I looked in all my shop motor & blower motor books & show lots of Fasco motors but nothing on the 7151-3547.. The other Fasco 220V motors all use a white common... One book did show the 7151-3547 was replaced by the D 658 but that motor has another speed & the wiring colors are different.. Some of the blower motors with 2 high speed wires showed them wired per Ohio Deere�s print & others showed the 2 high speed wires hooked together for hi..
It looks like you have a couple of options.. One is to use Ohio Deere�s print & see if it works,,, The other is to call a Fasco rep & see if he can access your motor�s wire diagram..
Make darn sure you hook the ground wire to the motor case before trying to power that motor up or the case could become powered & shock you a good poke..
[email protected]
Ohio Deere
08-16-2004 17:25:09
try this link out if it doesn't post automatically. I made a simple drawing for you to look at. the drawing shows a standard house light switch that is a three way switch that you can buy at any hardware.you can mount it in a box that accomodates the switch. also the wiring can be small considering it only uses 3 amps. a 18ga cord will do fine. also always use a ground wire from your service hooked to any metal on the motor in case of a short or bad motor it will trip the breaker and keep from "shocking you"
John T
08-16-2004 21:33:17
 Re: Clooney on the Electric Motor in reply to Ohio Deere, 08-16-2004 17:25:09
That corresponds to one of the ways I suggest he try, glad it matches your good diagram (pictures worth a thousand words lol). Not having any motor schematic, I guessed that L1 should go to a common, while the L2 might go to red for low and the 2 blacks tied together. Another other possible combination I guessed would be L1 and L2 to the 2 blacks for high???
John T
