47 JD AR
bobcaygeon
08-16-2004 09:00:26
looking for a brake band lined for a 47 AR.
any suggsetions?
Thanks in advance.
Kent W
08-16-2004 15:06:16
 Re: 47 JD AR in reply to bobcaygeon, 08-16-2004 09:00:26
When I checked two years ago JD only had the brake band assembly for sale and if I remember correctly it was over $120 for it. Luckily about that time a new old stock was on EBay that I was able to acquire for a lot less money. Now for your solution you may want to look for a shop that works on industrial type brakes and see if they can help. Drill out the old rivets, sandblast, straighten the stud, and paint the old band and they should be able to put new material on for you for less than $50.
Mike M
08-16-2004 09:44:30
Do you have your old band? JD should still sell just the lining and you can rivet it on.
