DISAPPEARING PETROL/GASOLINE
JOHNF2020
08-16-2004 07:24:11
HI-The gasoline from the tank on my 70d pony start is leaking between start ups(and no ,the tank is not leaking).Anybody any ideas where its going?
thanks.
buickanddeere
08-16-2004 08:26:29
 Re: DISAPPEARING PETROL/GASOLINE in reply to JOHNF2020, 08-16-2004 07:24:11
Are you following the factory operator's manual and shutting off the starting engine gasoline supply valve? Mounted on the dash and is to be shut off when the starting engine isn't running? I've seen the wife's cousins run thier 730D and it isn't pretty. They never use the gasoline shut off and were shutting the diesel off by either stalling it or pulling the compression release. Odd how they never used the compression release when starting? They looked awful supprised when I pulled the dash throttle shut off knob & shut the diesel fuel off via the throttle lever.
As the tractor vibrates/rock/rolls while driving some gasoline keeps splashing from the starting engine carb bowl. Then into the starting engine and down into the crankcase. The starting engine is likely smoking more now and will be rapidly wearing the crank/brearings/rods due to lube oil dillution. Time for a new starting engine float as it maybe getting "water logged" as well. Needle,seat and manual fuel shut off too if you have been using it but it's beginning to pass. Adding a small engine gravity flow filter in the line between the tank and carb is a good idea too.
