2030 gas to 3300 diesel
cowman2
08-15-2004 11:57:20
My 2030 locked so I recently purchased a 33OO with 1500 hrs and will be trying to repower my 2030 is there any advice or short cuts that anyone can help with. What do I need in addition to what is on the gas engine. Any help will be appreciated
WTW
08-16-2004 07:16:02
 Re: 2030 gas to 3300 diesel in reply to cowman2, 08-15-2004 11:57:20
Cowman, Your 2030 gas has a 202 engine, The 3300 diesel has a 219 engine. The rear engine flange / plate, oil pan and flywheel will have to be reused from your 202 gas engine over on your 219 diesel engine. The parts will fit directly over without modification. You will have to replace the rear main crankshaft seal when the rear plate is swapped over. Throttle rod will have to be changed or modified. I think the water pump on the combine engine will work. You may need a different exhaust manifold depending on tractor option / application. Muffler is the same. The last thing that may be different is the front pulley and again you can swap it with the gas engine. Air cleaners are the same from a gas to diesel but you will have to make up or purchase and air pipe to make the connection. Pretty easy conversion compared to other John Deere's. Good Luck, Dave W.
buickanddeere
08-15-2004 18:31:35
3300?
Fred G
08-16-2004 08:51:39
 Re: 2030 gas to 3300 diesel in reply to buickanddeere, 08-15-2004 18:31:35
3300 combine..... .
