36 AR Block
Tony
08-15-2004 09:52:04
I am in the process of redoing a 36 AR unstyled and come to the point of the block. It has a few pits in the cylinder and will need work. My question is, will it be cheeper to bore and new pistons, rings - or to bore new sleeve and same pistons new rings? If new pistons is it easy to get up to .090" overs? When I'm done it will not be a trailer queen, but one that will be used a little at shows and on the farm.
Thanks and have a great day.
MDM
08-16-2004 11:20:23
 Re: 36 AR Block in reply to Tony, 08-15-2004 09:52:04
if your pistons are good, it may be cheaper to sleeve your block and bore it to fit your pistons, if your pistons are worn, might be best to buy a set of oversize and bore block, has block been magnafluxed??
tony
08-17-2004 00:06:02
 Re: 36 AR Block in reply to MDM, 08-16-2004 11:20:23
No the block has not been mag-fluxed, does look good? The pistons are in good shape-don't know about the grooves without new rings to compare them. With the top tapered for the compression rings, by sleeves will the bother anything?
