Early D Generator Bracket.
Dave Brown
08-15-2004 08:35:55
Well summer is about over so it's time to start messin with the tractors. I have an early hand start D that I am converting to electric start. I have the generator bracket that attaches to the govenor, I also have the split pulley for the fan shaft. My question just so I under stand. The bracket is supposed to be at an angle so that the belt will figure eight. Is that correct? Does anybody have an actual picture of this set up? The manuals don;t have them?
Thanks,
Dave Brown
Clooney
08-16-2004 04:29:06
 Re: Early D Generator Bracket. in reply to Dave Brown, 08-15-2004 08:35:55
Dave, I have a picture here somewhere but can"t seem to find it at the moment [must have filed it incorrectly].. If I run across it I will send it to you..
That generator does sit at an angle & the belt does have a twist to it,, just make sure you twist it so the generator spins in the correct direction..
I haven"t done many D generators as I like the hand starts better [the older I get the more E/S appeals to me though].. On the couple I have installed a generator on I used one of those link type belts that is used for table saws & the like so it can be installed without disassembling the fan shaft.. The original D replacement belt was a take apart belt with a little latch type hook to allow installation..
[email protected]
