Glennon, that 045 engraved on the engine & flywheel could just be some sort of personal identifier, or could have been done a previous owner, or by a repair shop signify .045" oversized pistons.. It Isn't a Deere factory thing.. You ask.. Quote: "I would also like to know if there is a way to adjust the brakes, when applied they stick terribly and make a growling noise".... Asnw,, you can TRY adjusting them [square shank adjuster sticking out the rear of the backing plate] but usually when they stick & growl that means the drums are full of rust & the inner springs & operating parts are covered in rust.. You should probably pull the drums off & clean the inner parts, look at the springs for signs of stretching, clean lubricate the apply cams & make sure the pedal pivot is not sticking [you'll probably either have to do it now or later any so might as well be now].. Quote: " The clutch is also very stiff and is sometimes a real chore to disengage, can that be cured with an adjustment of the clutch?".... Answ,, that could be as simple as moisture in the clutch disks so if it will work at all try using the tractor for a while & see if it gets better.. Those clutches don�t get tight by themselves when being used.. If it was working good at one time & is now too tight to disengage that means moisture in the linings,, or the inner clutch parts have expanded from rust,, or are sticking due to rust.. For the time being you might try backing the [3] adjuster nuts off about a nut flat or two after pulling the clutch cover & [3] cotter pins.. If you see a lot of rust in the clutch after the cover is pulled you will probably need to pull the clutch apart & clean & de-rust all the parts.. [email protected]
