DLTX-71 carb sooted
wilhoit
08-14-2004 19:12:47
Just starting to rehab this carb. Everything on the choke side was covered with soot; the choke disk was bent and sooted on both sides. Would a backfire do this, or is there something unusual going on?
Clooney
08-15-2004 05:31:24
 Re: DLTX-71 carb sooted in reply to wilhoit, 08-14-2004 19:12:47
wilhoit, the black carbon [coking] is about normal on those old DLTX carbs [especially if the manifold heat control was left in the HOT position].. That bent choke plate is usually caused by either a backfire condition or loose choke plate attaching screws allowing the choke plate to hang up & bend when being moved.. The bowl vent in those DLTX carbs vents right near that choke plate so some of the evaporating hydrocarbons end up coking on the choke plate & carb bore in that area.. Make sure that bowl vent isn�t partially coked shut..
A good carb cleaning compound will get rid of the carbon & pulling that choke plate & laying it on a smooth flat surface will allow it to be lightly hammered flat.. Be careful when hammering on that plate, if you hammer near the edges it will expand the metal & make the plate difficult to fit back in the carb & work smoothly.
[email protected]
Mike M
08-14-2004 20:24:46
I have seen this before alot. I don't know for sure but I also thought a backfire caused the plate to bend,or someone working on it before with a pry bar and not a good fitting screwdriver. Sometimes you can straighten them enough to pull them out with vicegrips then you can lay it on a flat piece of steel and flaten out with a hammer or you could buy a new one. I think a small amount of soot is normal as most all have this. You should take a look inside a throttle body on late model cars GM for sure get very heavy deposits in them.
