JD 60 Overheating
Gusc
08-14-2004 19:11:44
I have a problem with my JD 60 overheating. It just started overheating this summer but is still doing it even though our weather is much cooler the past few days.
I have had this tractor for 22 years and it has always run so cool that I blocked off 4" of the radiator bottom and put shutters on it. I always kept the shutters closed for about the first half hour or so until it warmed up then I would open them about halfway to keep it from getting too cool again.
The radiator is not pressurized because the cap flange is messed up but it has been like this since day one.
I rebuilt the water pump in Sep 2000; adj thecarb, added new plugs, points, cond, rotor, cap, new coil, plug wires and adj the timing in March '01. I cleaned and rotated the spark plugs in July '03. Added an alternator in Feb this year and just yesterday cleaned the radiator fins and the grill. In all this time I probably have not put 50 hours on the tractor.
As you can see I have done nothing this year or since July '03 that I can see that could possibly make it overheat.
I can run it for about an hour with a lightweight 5' bush hog cutting pasture grass, mostly fescue, and the temp reads just short or 200 degrees. At that point I quit because that is a bit too hot. I'm running at about 3/4 throttle in third gear but in the past I ran almost wide open in 4th with no sign of overheating.
My first guess is that it is running too lean or the timing is off but this hasn't been changed since '01 so it should have shown up long before now.
Also I'm just guessing that maybe the radiator is clogged so my next step is to back flush the cooling system but this is just blind guessing.
Since I am lazy I would like to get any ideas some of you JD 60 owners might come up before I go any further.
Thanks,
Gus in Arkansas
Mike M
08-14-2004 20:33:10
 Re: JD 60 Overheating in reply to Gusc, 08-14-2004 19:11:44
I would try to flush the radiator inside and out. Have you filled it clear up full and looked for air bubbles when running indicating a leaking head gasket. Some of the traveling tool trucks matco,snap-on,etc. and maybe other places sell a little tool with chemicals that change color that you can use to sniff inside of radiator for combustion gases.
gusc
08-15-2004 12:32:33
 Re: JD 60 Overheating in reply to Mike M, 08-14-2004 20:33:10
Mike,
I think you are on to something here. After I filled it to the top it did seem to be foaming out
the filler while I was mowing but I was bouncing around and couldn't tell for sure. I should have stopped and checked but it was getting dark and I was in a hurry.
Are failed head gaskets common on the 2 cyl?
I forgot to mention that the water jacket was cracked on the bottom just to the rear of the cylinder drain petcocks when I got the tractor.
I filled the crack with JB weld years ago and stopped 90% of the leaking. Since the overheating problem just started I don't think that is the cause.
It could be that the crack has expanded into the cylinder. I better drain some oil from the crankcase to see if there is any water in it.
Thanks for your input.
F-I-T
08-14-2004 19:25:10
Gus:
Any chance you have a thermostat that is stuck closed? Maybe it was stuck open for a long time (explaining your running cool problem) and now it has closed for good.
I'd check the timing. You could add a little fuel on the load adjustment and see how she fairs, but with the little bit of work you're making it do, it shouldn't overheat.
Frank
gusc
08-14-2004 20:01:17
 Re: JD 60 Overheating in reply to F-I-T, 08-14-2004 19:25:10
Frank,
The 60 thermostat is in the bottom of the radiator tank and only functions to open or close shutters. It doesn't work so I work the shutter manually but the thermostat doesn't block coolant flow.
I'll try the timing and load mixture if nobody comes up with a better idea, but these shouldn't have changed unless the point block is worn down too much or a power valve is partially blocked by gas gum.
Thanks,
Gus
