3020-lights--no lights
Levi
08-14-2004 18:52:44
The lights on my 3020 won't come on at low idle, but do when I idle up. Is this just a 24volt thing or is something wrong. I just put in new batteries, gen., and VR. Thanks in advance.
will
08-15-2004 05:57:39
 Re: 3020-lights--no lights in reply to Levi, 08-14-2004 18:52:44
Sounds like a poor connection some where. The lights are 12v not 24v., with one side + ground and the other side - Ground. Check your grounds, The left battery should ground to the frame from the + post and this also gives you a ground from the - post of the right battery through the heavy cross cable. The fenders need a good ground to the frame to get current to the lights. Also clean up the harness connections. That just leaves the just the switch, braker, and harness to test if you still don't have lights. People don't like the 24v system, but I've had no more trouble with it than 12 volts and we have had two 3020s since they were new in the 1960s. Get a manual if you don't have one and study the wiring. It's confusing at first, but will make sense after a while.
