Anyone who has 435 with power steering
GM435
08-14-2004 14:36:00
According to my parts book the hydraulic pump on a 435 with power steering was made by Webster. I need to get the Webster model number. Would someone who owns one please check their pump for that model number. Thanks
Henry J
08-15-2004 10:30:40
 Re: Anyone who has 435 with power steering in reply to GM435, 08-14-2004 14:36:00
GM 435
Per chance do you know if the ps pump is the same as that on a 430 or 440.
I am probably wrong, but suspect that JD woulda done something like use the same on on those tractors. I have a 430 pump on the bench. It doesn't have a casting number on the pump, but does have a number stamped into the tank.
However, what makes me think I am wrong is that I was able to get parts for mine at JD.
Shout back if it is a bingo.
GM435
08-18-2004 18:41:57
 Re: Anyone who has 435 with power steering in reply to Henry J, 08-15-2004 10:30:40
Here is what I know. The 440 (gas engine) that I have seen uses a power steering pump with a built in reservoir. It did not have any other hydraulics. The 420/430 parts book I have shows a simple hydrualic pump, which uses the 3pt hitch reservoir. It has a separate diverter valve to feed the power steering. This pump is probably very similar to the 435 without power steering. The 435 with power steering uses a pump with a built in diverter valve, and uses the 3pt hitch reservoir.
