620 orchard hyd. pump
fixerupper
02-02-2004 15:35:57
Will a 620 orchard hydraulic pump fit on a 630 row crop? During the years when our 630 was used for daily loader work I always wanted a little faster pump and I found out the 620 orchard has a bigger pump because it does not have a separate power steering pump so the power steering pressure comes off the main hyd pump. The orchard also has pressurized oil fed to the idler gear that drives the hyd pump where the other models rely on splash lubrication. I plumbed an oil line to that gear about 20 years ago and have not replaced the gear since then. Before that was done it was every other year. I don't use the loader nearly as much now so the need for speed isn't there anymore, but I am still curious. Can a person even find an orchard pump?
fixerupper
02-03-2004 21:44:16
 Re: 620 orchard hyd. pump in reply to fixerupper, 02-02-2004 15:35:57
My neighbor used to have a 730 gas and he said it had a lot of guts but it seemed to be thirsty. Some guys buy a bigger tractor and complain about it being hard on fuel, not thinkig about the fact that it usually takes more fuel to make more power.
fixerupper
02-02-2004 19:51:55
Thanks for the info, Jim. I don't suppose a person could get the gears and shaft now. Next time I get to the dealer I'm going to ask him. You must have had a healthy 720 to be able to pull that Heston 30.
Poor Farm Jim
02-03-2004 19:47:45
 Re: Re: 620 orchard hyd. pump in reply to fixerupper, 02-02-2004 19:51:55
fixerupper,
I've wondered the same thing myself over the years. Yes, the 720 Gas was (is) a pulling fool, we bought it burned 30 years ago and I've still got it. I hear people complain about how thirsty they were but I never thought it did that badly on gasoline consumption. I never did get out of second gear much though pulling that stacker. Dad bought the tractor from a fella he went to grade school with; I ran into his son a year ago and asked if he remembered the tractor. He said he was plowing at night when it burned, doesn't to this day know why. Said he'd like to buy it if I ever decide to sell.
Poor Farm Jim
02-02-2004 17:45:08
Dad and I put one on a 720 Gas back in the mid-70's because we were pulling a Hesston 30A stacker with it and needed to get that roof up and down faster. Seems we just bought the two wider gears and the wider middle section of the pump. It's still on there, runs the log splitter a little faster than the 620 or 720D.
Jim
