*****JOHN DEERE 70 STANDARD DIESEL********
BUBBA
08-14-2004 13:16:22
hello
i am in the process in buying a JOHN DEERE 70 standad diesel. it has fair tires, original paint, runs good, power steering, hydralics. asking price is $4,000. is this too high or low?
thanks Bubba
Dan in Ohio
08-14-2004 14:35:05
 Re: *****JOHN DEERE 70 STANDARD DIESEL******** in reply to BUBBA, 08-14-2004 13:16:22
Bought mine for less, not running, with adj. WF and rockshaft. Look closely at the pony, if its good, that is a good price. They are great tractors.
BUBBA
08-14-2004 14:48:48
 Re: *****JOHN DEERE 70 STANDARD DIESEL******** in reply to Dan in Ohio, 08-14-2004 14:35:05
the pony on this tractor runs great but smokes, the owner say hes has gone through the pony though
buickanddeere
08-14-2004 22:07:40
 Re: *****JOHN DEERE 70 STANDARD DIESEL******** in reply to BUBBA, 08-14-2004 14:48:48
If the starting engine still smokes, they missed something. Maybe as simple as an oil change, people often leave the gasoline valve open and dilute/thin the crankcase oil with gasoline. Could be as $$$ as scored pistons and sleeves polished way undersize & oversize to remove rough spots.
Dan in Ohio
08-15-2004 07:31:45
 Re: *****JOHN DEERE 70 STANDARD DIESEL******** in reply to buickanddeere, 08-14-2004 22:07:40
Both of my 70 D's ponies smoke, one much more than the other. I plan to pursue the cause of the one that smokes the most, but both start and run great otherwise. This is a contraversial subject. Theoreticly one that has been (gone through) should not smoke, but have you ever seen one not smoke at least some. Makes a seen at the shows I go to and I don't like that.
