70 gas running on one
Leon
08-14-2004 12:19:11
My 70 gas only runs on the right cylinder. The carb has been gone through by an ex-service manager from the 2-cylinder era who now basically makes his living repairing old JD's. It has a new electronic ignition with new wires and coil, the compression is 105 psi (same in both cylinders), the tappets are set at .022 cold, and it doesn't matter if you switch the plugs around. What else could it be??? It's really got me stumped! FWIW, the previous owner replaced the manifolds(with repros). Could he have messed something up? TIA!!! Leon
Clooney
08-15-2004 06:15:13
 Re: 70 gas running on one in reply to Leon, 08-14-2004 12:19:11
Leon, a few things can cause your R/H cylinder to not work.. You have accounted for some with the compression test & valve adjustment..
Start by pulling the choke partially to mostly back on & if it starts firing on two cylinders you probably still have carb problems.. Those Dual DLTX carbs are VERY difficult to get the idle circuits clean on so there is a good possibility something was missed when it was overhauled [even the best carb man can miss a problem in those DLTX carbs unless he personally puts it on the tractor & try�s it when done]..
If the choke back on doesn�t help then MAKE SURE the manifold heat valve is set to EXACTLY HOT or COLD & not in between.. If in between it can block off part of the exhaust flow..
Next MAKE SURE your distributor spark rotor is correct & lines up with the cap contact for the R/H side when the points open for that side.. The Cap MUST also be correct for that 70.. There are a few different caps & rotors out there & not all will work with each other.. You can use a timing light on both sides to verify the spark is occurring at the correct time.. Obviously the L/H side should be easy to see with the light as it is working,, for the R/H side just make sure the spark appears when the flywheel slot is the same position [only it will be upside down for that side]..
Other than that make sure the valves are opening the same for both sides & the valve springs have about the same spring tension�
One last thought�A few years a go I put a repo manifold on & it didn�t fire strong on one side at idle so I pulled the manifold & found a pea sized casting defect hole in the manifold runner�just a thought�
Any questions on the above just post back�
[email protected]
gus
08-14-2004 20:15:08
Leon,
The only times I ever have this problem on my 60 is when one of the plugs fouls and bridges the gap because mine pumps a lot of oil.
Are you sure you are getting spark to the plug and fuel to the cylinder at the right time? You could have the plug wires reversed. Try changing the plug wires in case you have a bad wire.
You can reverse the plug wires at the distributor cap but I'm not sure this is a good idea. See what the experts say.
I seem to remember that it will still run with wires reversed but not very well.
Jim Dunn
08-14-2004 14:13:19
I am in the process of restoring a 520 that my father-in-law bought in 1958. For many years now, it has started on one cylinder and picked up the other one only after the tractor warmed up. The colder the weather, the longer it would take to pick it up. While overhauling the engine, I found that it had a crack in the number two cylinder and after giving it much thought, I figure that moisture was accumalating with in that area and wetting the plug until heat would dry it out. It was a small crack and I was able to weld it up. I just got it back together yesterday and it sounds good. This just might be your problem also if it ever got hot. I need a wiring diagram for my 520. Do you have any suggestions?
Jim Dunn
Mike w J
08-15-2004 07:21:09
 Re: 70 gas running on one in reply to Jim Dunn, 08-14-2004 14:13:19
check valves make sure they are set right if the left one is way off I would suspect a bad cam bearing. My 60 did that and it was the left bearing.
