dwm
08-14-2004 07:50:44
Have a 1948 D. Sat for several years in a barn. Checked and cleaned the gas tank, carb, lines, mag, crankcase, valve action, compression, etc. New plugs and wires, clean fuel supply. Tractor will run, but wants to backfire, a loud pop through the muffler. Working the choke seems to affect it, though adjusting the carb seems to have little effect. Compression is low in #2, about 25 pounds, #1 ok. Cam seems fine, valve lash checked, mag is firing at right time per flywheel mark. Could not get one of the brass plugs in the carb out, all other passageways clean. Have surmised problem is either that particular passage is blocked, requiring the brass plug to be drilled out. Next step could be putting on a known good carb. Have also speculated about the effect of the low compression on #2, but was trying to avoid pulling it apart yet. Any other help or ideas would be appreciated. Thanks, dwm
