2355 no power
Chris
08-14-2004 05:37:17
Hi, I just bought a used 2355 fwd with a 245 loader. Got it home and thought it felt dead, so I took it to the massey dealer and put it on the dyno. All it would put out is 25 hp. I have changed all the filters, the return line is clean, the lift pumps seems ok. The tractor does not skip or sputter, just no guts. I thought it must be in the pump, sent the pump away, had it tested, repaired, and turned up, so the tractor will be about 65 horse. The only thing they found wrong in the pump, was the blades were worn, and the eccentric ring. I put the pump back on and the tractor is no better. Does anyone have any ideas where i can go next? I have not done a compression test, but have done a oil pressure test and that seems fine. I would appreciate any help I could get. Thank you
Grego
08-14-2004 12:14:20
 Re: 2355 no power in reply to Chris, 08-14-2004 05:37:17
The spec is for about 56hp at the PTO as I recall.
I have not dyno'd mine, but that rating seems about right. Mine runs an 8" chipper all day in the summer without raising a sweat.
The 2355 is a very sweet tractor. Excellent choice.
Personally, I would suspect the injection system. If you end up replacing the injector pump
be aware that the only difference between the 2355 and the 2555 is the injector pump, or so I have been told. So you can grab some extra ponies
with a 2555 pump.
-grego
G-MAN
08-14-2004 07:13:26
Oil pressure isn't going to affect power, unless you have none. I'd pull the nozzles, test them and do a compression check. Also double-check the timing. When you mentioned changing filters, you did put new air filters in, right?
