3020 gas stalls out under load
dlmyer
08-14-2004 04:55:50
My 1967 3020 gas with points and condenser will sputter and die while under load at full throttle grinding feed. The fuel pump seems to pump gas fine and is a replacement and has inline filter just before fuel pump. The tractor will start right up and operate fine again for a few more minutes.
Huckleberry
08-14-2004 10:17:36
 Re: 3020 gas stalls out under load in reply to dlmyer, 08-14-2004 04:55:50
for what its worth....I once spent a week with a similar problem with my gas 2520. Finally took the fuel tank off, turned it upside down and shook it...a large beetle about the size of my thumb fell out on the ground. How it got in there? I don't have a clue.
msb
08-14-2004 07:51:23
Have you tried removing the fuel line from the tank and blowing it out?Sounds like it may be clogging up.
