Deere plow 5C or 6C
Larry in Lone J
02-02-2004 14:39:53
According to the archives (thanks Dean and Mike), my old plow is a 5C or 6C based on the beam numbers (484, 458, and 457). It is a 3 bottom plow.
What is the difference between the 5C and the 6C?
The rear wheel is the "bottle cap" style. The front wheels have automotive type wheels now and I'm assuming that is not right due to the age of the plow. What do the original wheels look like? (part numbers would be nice??) and where might I find a picture?
Thanks!!
Bob Collins
02-03-2004 08:38:31
 Re: Deere plow 5C or 6C in reply to Larry in Lone Jack, 02-02-2004 14:39:53
Larry, First I told you you had a 5C plow then I went on to describe the wheels on a 6C. Actually they are pretty much the same except I think the 5C was not built with the cast land wheel. It could be ordered with a cast furrow wheel for muck land (M528) or JD1318 steel wheel 26x6 1/2". Now are you confused?
Larry in Lone Jack
02-04-2004 14:29:25
 Re: Re: Deere plow 5C or 6C in reply to Bob Collins, 02-03-2004 08:38:31
Well, Bob, you had me going for a minute! I think I know the difference now. All I need is a picture, or two, so I can hunt for some original wheels. Thanks for the response.
Bob Collins
02-03-2004 08:20:36
Larry, If you have beams 457, 458, and 484, I think you have a 5C, My information says the 6C plow used the 457 and 458 beams but used a third beam number 473. This #473 shows up on all the versions of the 6C plow 12" 14" 16" 3, 4, and 5 bottoms. The 6C often used the "bottle cap" wheel on the land side, this really looked like a bottle cap (17904)having a fluted edge although later (after 1928) ones were smooth and used 10 bolt on lugs. I think I remember seeing a later yet #6C with a cast spoke land wheel # D447A a really nice looking wheel. The furrow wheel should be a 26" diameter steel spoke wheel, 4" (JD328)or later 6 1/2" (#197)wide. There are often wheel options that can be special ordered without even showing up in the parts catalog. Bob
