Correct ring gap
Chuck
08-13-2004 18:43:40
I am overhauling my 43 B. The cylinders are only about 0.012 - 0.016 over standard (1 - 2). The service manual does not give a spec for this measurement. I have heard that the proper gap for a ring is 0.005 in. per bore inch, or 0.025 in. in my case. Can anyone correct of give the proper figure?
Thanks in advance
Mike M
08-14-2004 04:42:36
 Re: Correct ring gap in reply to Chuck, 08-13-2004 18:43:40
How are you coming up with that figure ? An inside mic, or measureing ring gap ? The only way to know for sure where it's at is to use a mic. If you are worn .012-.016 over this is a lot of wear or taper as the bottom of the cylinders are probabaly still standard.
Chuck
08-13-2004 18:44:48
Oh, I don't want to rebore with this little wear, just rering it.
