2510 Gas will not turn up
jdman(MO)
08-13-2004 17:13:27
Just brush hogged 2 acres, now tractor is missing at full throttle. Will start and Idle, but any rapid advance of the throttle and it falls on is face. Checked plugs, looked good. Checked fuel sample from carb, looks good. Took Fuel sample from truck tank, looks good. Cleaned points, and checked wires. Has fuel filter, and it was clean and un-restricted. Sounds like fuel, but.. plenty of pressure on line that goes to carb. Any ideas. Russ
msb
08-13-2004 18:53:20
 Re: 2510 Gas will not turn up in reply to jdman(MO), 08-13-2004 17:13:27
Have you checked the distributor advance mechanism for freedom of movement?Remove the plate the points fasten to and have a look at the springs to see if any are broken or unhooked.Put a couple drops of oil under the rotorto lubricate the shaft.--- Could also be some dirt in the load speed jet.--- A plugged up air cleaner?
jdman(MO)
08-13-2004 20:48:52
 Re: 2510 Gas will not turn up in reply to msb, 08-13-2004 18:53:20
New developement. Tractor runs pretty good with choke 3/4 out. Russ
jhill
08-14-2004 05:38:04
 Re: 2510 Gas will not turn up in reply to jdman(MO), 08-13-2004 20:48:52
If it run wjth the choke 3/4 out you have a fuel delivery problem. Pulling choke creates more vacuum which pulls fuel from bowl at a lower level. Check to see that the inlet in the tank is open and fuel lines aren't clogged. Fuel pump is working properly and float needle is open.
jdman(MO)
08-14-2004 07:49:45
 Re: 2510 Gas will not turn up in reply to jhill, 08-14-2004 05:38:04
Cleaning carb fixed the main problem, but now seems to be running rich at idle. Got to go on vacation, will tackle the carb again when I get back. Thanks to all. Russ
Mike M
08-14-2004 20:53:27
 Re: 2510 Gas will not turn up in reply to jdman(MO), 08-14-2004 07:49:45
I think those carbs. might be the ones where screwing the idle needle in richens it and out leans it. They adjust the amount of air and not the fuel. Could it be this ??
