Dan, bottom line is if shes not charging, it could be a wiring problem or a Voltage Regulator (VR) problem or the Generator itslef, so I will try n take you through it one step at a time. 1) PRELIMINARY: Make sure the belt is good n tight and not glazed slick,,,,, ,the Generator and VR are BOTH well grounded (you could run a ground wire direct to it from the grounded battery post),,,,, and that the VR"s BAT terminal always reads HOT battery voltage. 2) Is the ammeter wired correct and do BOTH its terminal always read hot battery voltage??? Its load (NOT to Battery) side has to be wired to the ungrounded battery terminal and its other load side has to be wired to the BAT terminal on the VR. 3) WIRING: BAT on VR always must be hot ad wired to the ammeters load side,,,,, ,,FLD on VR wired to Gens Field post,,,,, ,,,,GEN (or ARM) on VR wired to Gens Armature post,,,,, Gen and V BOTH well frame grounded. 4) Does the ammeter work and swing to discharge if lights turned on tractor not running????? 5) TO SEE IF ITS A GEN OR VR PROBLEM (AFTER you have checked all the above first) a) FIRST, polarise my momentarily flash jumping a wire from the BAT terminal on the VR over to its ARM terminal and you should get a spark. b) With tractor running, ground the Gens Field post to its case and see if it charges then?? If so, the VR is bad,,,,, ,,or the wires misisng from the Gens Filed to FLD on VR,,,,, ,or the VR isnt grounded. c) If still no charge,,,,, leave Field grounded and jump the VR"s BAT and ARM terminals together. If she charges then, the VR"s cutout relay is bad or misadjusted. d) With BOTH above you have essentially by passed the VR functions, so if still no charge and all esle above is good wired correct, you likely have a bad Generator. 6) Common Gen problems may be the brushes are worn or the hold down springs are stuck/corroded and not pushing the brushes tight down against the commutator or the armature or fields are bad. Ive made many work again simply by cleaning n lubing the hold down springs. I have different JD wirign diagrams (didnt get any off the net) so e mail me at [email protected] if you want any. Theres more but Im getign tired, Ive answered some tractor e mails and several long posts here n Im tireddddd ddddd Post back or e mail any questons and let us know what happens Good Luck n God Bless ya John T [email protected]
