JD 4000 HYDRAULICS
RALPHR
08-13-2004 11:30:21
I AM HAVING A PROBLEM WITH THE HYDRAULIC PUMP ON MY 1972 JD 4000. WHENTHE CLUTHC IS DEPRESSED EITHER PARTIAL OR FULLY DEPRESSED, THE HYDRAULICS FAIL. YOU HAVE TO PUT THE TRATOR IN NEUTRAL AND BUMP THE THROTTLE AND WAIT TILL THE PUMP REPRIMES AND ALL HYDRAULICS RECOVER INCLUDING STEERING. DOES ANYBODY KNOW WHATS WRONG AND HOW TO REPAIR? I HAVE HAD SEVERSL 4020'S THAT DO IT BUT NEVER AS BAD AND DIDN'T KNOW WHAT CAUSED IT THEN.
WTW
08-13-2004 14:37:03
 Re: JD 4000 HYDRAULICS in reply to RALPHR, 08-13-2004 11:30:21
Ralph, Could be many different things, like low transmission output caused by restricted suction screen or plugged filter or just a tired transmission pump. The transmission pump only runs when you have your foot off the clutch (clutch released). If everything seems to be normal once you have it working. Sounds like you have a high pressure leak to sump. What this means is good chance there is nothing wrong with either of your two pumps, transmission or main hydraulic pump. What is happening is at an idle a system on the tractor could be any hydraulic function, Brakes steering, SCV's, or hitch is taking / leaking oil into the sump side of your hydraulic system. Your tractor has a closed center hydraulic system and when not using a hydraulic function it should not be using any oil away from the main pump. If it is taking oil when not needed it robs the system / front reservoir of it storage and at an idle the hydraulics will stop about as fast as you step down on clutch pedal because there is no oil left in front reservoir for it to run on as it was used up supplying a leak somewhere in the system. It can be found and repaired but will take some testing to figure out. To make a long story short you may have a small problem creating another. The best money spent, is with someone with some knowledge of tractor hydraulic system. If you were in the vicinity of Eastern Iowa I would be happy to fix it for you. Good Luck, Dave W.
