JD 260 Lawn Tractor
curtt
08-13-2004 09:37:21
The battery light has recently come on, which indicates discharging. I"ve replaced the battery, but the light remains on. The owners manual is no help. What other things should I be investigating? Any help is appreciated.
Thanks
Curt
MarkA.
08-13-2004 17:53:32
 Re: JD 260 Lawn Tractor in reply to curtt, 08-13-2004 09:37:21
There is a regulator rectifier under the dash above the battery. They have a tendency to get loose at the connection and burn the plug-in. Should be able to pull the plug-in apart and replace the bad connector.
curtt
08-14-2004 06:25:05
 Re: JD 260 Lawn Tractor in reply to MarkA., 08-13-2004 17:53:32
Thanks for the reply. I'll take a look at that and see what I find.
Curt
Henry J
08-13-2004 12:54:48
Curtt
First thing I would do is put a digital volt meter across the battery terminals and see if the thing is charging or not.
