1950 JD A headgasket
Mike Yac
08-13-2004 08:45:40
Need some advice
Have all sheet metal off 1950 JD A
Can head & manifold be removed as unit without removing upper water pipe and/or fanshaft ?
What is best tech manual to read for instructions, torque etc....JD has no service manuals on the A for this year
Do you put any sealer on the gasket ?
Thanks all
Mike CT
Mike M
08-13-2004 09:34:38
 Re: 1950 JD A headgasket in reply to Mike Yac, 08-13-2004 08:45:40
That head and manifold are made to come out as an assembly,you don't even need the hood off.You just have to twist and turn it the correct direction as it may only come out one way. The manuals from I & T are better than none at all and should give you the specs.you need.
I have coated some in the past with copper coat or aluminum paint. I just did a 720 D and used permatex # 3 like the book says. Still looking for that magic potion. You may want to look into a gasket from Lubbock gaskets in TX. a lot of pullers use those. I was going to use one on that diesel but found out they were only reccommended for only 300 lb compression.
Mike Yac
08-15-2004 10:41:43
 Re: 1950 JD A headgasket in reply to Mike M, 08-13-2004 09:34:38
Mike M
Thanks, appreciate the feedback and that was the answer I was hoping for.
Regards
Mike Yac
