1935 D - Magneto Is Mounted Different
cheg
08-13-2004 05:31:02
On my 1935 D, the magneto is sitting on a base with a coupler connecting the mag to the governer. The mag is a Wico X. I have never seen one this way. The housing has 3 bolts at the governer mag output shaft. All the D's I have seen have the magneto mounted on the governer housing without this base. These governer housings have 4 bolts that hold a housing for the magneto to bolt to. Do I have a tractor that somebody modified?
Clooney
08-13-2004 07:44:58
 Re: 1935 D - Magneto Is Mounted Different in reply to cheg, 08-13-2004 05:31:02
Cheg, there were some conversions for adding the Wico X mag to the early base mount U/S D"s.. It sounds like you have one of those conversions.. Probably not too unusual but I have only seen a couple..
[email protected]
cheg
08-13-2004 09:02:18
 Re: 1935 D - Magneto Is Mounted Different in reply to Clooney, 08-13-2004 07:44:58
I did some internet research and found my answer. That Wico X (XH1263)is the correct magneto for the D. There was a run of serial numbers that had a base mounted magneto with a fiber float for a coupler. It is amazing how the tractors are so similar, but yet so different.
Thanks Clooney!
