955 3-point hitch won't go down
bob hornak
08-13-2004 00:39:44
the 3-point hitch on my 955 compact won"t drop down after the tractor has been used for a while. once the machine has cooled down it again functions normally. The hydraulics work properly for the front end loader even when the 3-point does not. Any help would be appreciated.
leon
08-13-2004 04:06:59
 Re: 955 3-point hitch won't go down in reply to bob hornak , 08-13-2004 00:39:44
Now that's a strange one. My immediate thought was that the 3-p0int hitch "rate of drop" valve located under the seat is too far closed, but considering that it drops OK when cold but not when warm, that doesn't seem to point to that valve as the culprit. None the less, I'd still suggest that you check to see that the valve is opened up plenty far. Turn the knob on the valve CCW to open.
