4840 quit pulling! Help!
scottAR
08-12-2004 19:36:07
This afternoon my 4840, suddenly quit pulling, has no hydraulics or power steering. Engine runs good and nothing makes irregular noise. Fluid levels are good and I changed the hydraulic and trans filters with no response. What next?
DON
08-16-2004 06:54:55
 Re: 4840 quit pulling! Help! in reply to scottAR, 08-12-2004 19:36:07
REMOVE THE CENTER LINK MOUNT, BEHIND IT IS A PLUG, REMOVE IT AND YOU WILL SEE THE DRIVE SHAFT FOR THE TRANSMISSION PUMP. PULL IT OUT OF THE TRACTOR. THE SPLINES ARE PROBABLY STRIPPED AND /OR SHAFT IS BROKEN. IN EITHER CASE THE ROCKSHAFT NEEDS TO BE REMOVED AND A NEW PUMP AND SHAFT INSTALLED. HAD A 4630 DO THE SAME THING THIS SPRING.
scottAR- thanks guys-
08-13-2004 19:11:29
I believe you have me on the right track.
G-MAN
08-13-2004 07:50:58
I agree that it's probably the damper disk, but the easiest check to make is pulling the sump screen. If the screen is clean, the odds of it being the damper just got a lot stronger. When the tractor is split it's also a good time to pull the clutch pack and inspect it. They're easy to remove and disassemble and it's cheap insurance. I'd reseal the pistons, replace the belleville washers and snap rings, and inspect the trans pump and replace the seal. That's standard procedure for us when we have an 8-speed split. And definitely replace the rear crank seal.
JDGnut
08-12-2004 20:42:54
Sounds like the damper is slipping... it is basically a dry clutch that is bolted to the flywheel.. when it stops turning.. so does the transmission pump... It will require the tractor to be split at the clutch housing/engine... look at the rear main seal while your in there... Good Luck... Lets us know how you come out..
JDGnut
Tyler
08-12-2004 19:55:06
If you dont have any hydraulics at all, including the hitch. I would bet the farm that your torsional dampner in the flywheel stripped out. Has to be split between the engine and clutch housing to change it. I have rebuilt ones for $330.00 exchange.
Tyler
1-800-538-8350
jimks
08-12-2004 19:53:42
also check to see if the pump coupler splines are stripped.
johndeere_doc
08-12-2004 19:43:41
sounds like either the sump screen pluged and the trans pump is not getting oil or the pump went bad. if this pump is not pumping you have no engagement oil for the elements in the transmission and assuming that it is a powershift since thats the only transmission you could get with a 4840. first i would check is the sump screen make sure it isn't pluged. it is the plug on the left side of the tractor in front of the final drive. you will have to drain the oil
