How To Modify JD Metal Seat to Battery Cushion Sea
Charles
08-12-2004 17:33:56
I have a 1946 John Deere B and would like to know if there is some way to modify the metal seat to a cushion seat like the late styled (over the battery box or something similar).
I saw a 1943 B at a show one time that had something like it, but at the time I didn't pay close attention as to exactly what was used.
Does anyone have any ideas or suggestions?
Thanks Charles
TractorNut
08-12-2004 21:44:14
 Re: How To Modify JD Metal Seat to Battery Cushion in reply to Charles, 08-12-2004 17:33:56
Charles, send me your email address and I will email you a picture of how to replace the pan seat with the cushioned seat.
JDGnut
08-13-2004 05:44:31
 Re: How To Modify JD Metal Seat to Battery Cushion in reply to TractorNut, 08-12-2004 21:44:14
I figured you might chime in here somewhere..... JDGnut
JDGnut
08-12-2004 21:10:01
Dad build a nice setup on his B... He took a frame from a square seat, and replaced the stock C-channel a new piece, and kept the stock mount to the floorplate, and the stock seat spring... bent the C- channel back simialar to the stock, but lower.. then mounted the the square frame to the C-channel... (don't remember what he used.) Now he has the padding from the Square seat.. and the spring from the panseat frame.. makes for a nice ride.... JDGnut
Clooney
08-12-2004 18:53:40
Charles, like you I have seen the late battery box seat added to the early tractors.. While I didn't look real closely, the few I have seen used some angle iron brackets to come up off the rear housing to bolt the battery box to.. The battery box kind of cantilevered off the rear a little.. I will look at some of my archive photo�s to see I have any pictures of a battery box conversion.. If not I know of a show later this year that usually has an early tractor with the late battery box & I will shoot you a picture..
[email protected]
