Hey blksmok, ref what's wrong with 620.....
Fred
08-12-2004 17:28:20
I checked the choke plate like you sujested. It was still fastened good. I checked the valve adjustments and the throttle plate.
I can't get it to run at all, much less on just one cylinder now. It'll act like it wants to fire up, but spits out some dark smoke and quits.
Any more ideas? Thanks!
BushogPapa
08-12-2004 18:10:32
 Re: Hey blksmok, ref what's wrong with 620..... in reply to Fred, 08-12-2004 17:28:20
Change the plugs....they are fouled, now.. Maybe that is your problem now..
BushogPapa
08-12-2004 18:08:56
Do you think it is oil, or gas that is the problem..?? A plugged air intake will do that--but is not as common on a "20 series"..happens a lot on the "A" B, or G... I guess you should try it with the intake tube removed from the carb, to eliminate that part of the system.. Too much oil in the aircleaner cup can cause a lot of smoke.. Your crankcase is not loaded with fuel, is it..? Keep us posted...!! Ron.
BushogPapa
08-12-2004 19:18:16
 Re: Hey blksmok, ref what's wrong with 620..... in reply to BushogPapa, 08-12-2004 18:08:56
Sounds like you may need to drop the float bowl and clean out any crud that has accumulated.. Sometimes enough crud accumulates to interfere with fload movement.. While in there, clean the 2 orifices that extend toward the bottom, and the needle and seat should be checked for any dirt around that area, or above the needle, trying to get thru it, and causing it not to seat..
Fred
08-12-2004 19:22:53
 Re: Hey blksmok, ref what's wrong with 620..... in reply to BushogPapa, 08-12-2004 19:18:16
OK, did that already. But as far as the orfices being clean, well..... .I didn't have the proper tools. I removed the 2 caps on the bottom on each side. They appeared to be clean.
As far as the main needle in the middle, a few years ago I removed it and the tip looks to be broken. It doesn't have a tapered point. It has run for a few years like that however.
Fred
08-12-2004 19:05:48
I should've posted all the info again from a few days ago. I'd have to go back a few pages to see just what I did post.
Anyway, I did try it yesterday with the air cleaner elbow removed. Tried brand new plugs and swapped wires the other day while it would run on the right cylinder.
And, it's gas smoke, like it's flooding. What would cause a carb to start flooding like that all the sudden, assuming it is the carb maybe?
Now it won't run at all. Wanted to try pull starting it today, but no help around.
Thanks for any ideas.
