JD 520 Rear Axle Hubs
Steve59
08-12-2004 16:04:04
Does anyone know any tricks to getting the Hubs off after the following has happened.
The 3 7/8 bolts broke near the Head. One of the Jack bolts was already broke the second has so much rust around that will not move. We have tried hitting the Collar that is supposed to go back Tried hitting the wheel itself Put a Jack against the axle with chains to the wheel. We even tried making a sleeve so that the jack pressure would go against the collar and not the axle. Also we have heated the hub to try to expand and break some rust. Tried Rocking the Wheel adjusting nut but that is froze up and won't budge. Any one who has had this problem or has some ideas that I havent tried let me know. The tractor is not running so can not drive around to try to horse it loose Thanks; Steve
BushogPapa
08-12-2004 18:23:18
 Re: JD 520 Rear Axle Hubs in reply to Steve59, 08-12-2004 16:04:04
Since the 3 clamping bolts are broken, they should not be a problem.. Try to get that other jack bolt out...then you have a good way to get penetrating oil into the center of the hub and on the wedge.. Soak the hub well, for a few days... For heat, I use an old gasoline blow torch...about 45 minutes on the hub should be enough...( not on the axle)... Then, have a heavy-walled pipe ( cut a notch out, so it only hits the wedge half) that will slide over the axle..weld a good plate on the end you are going to hit with a sledge hammer... With the hub HOT and soaked..AND the pipe and sledge hammer..it IS going to come loose...!! Hit it "like you mean it"..!!! Let us know... Ron.
Jon C -Florida
08-12-2004 16:45:43
Steve -
Just curious , what tractor/wheel is this on. Some of the three bolt collars have space to drive a steel wedge in between the collar and the wheel. However, many do not, as the wheel hub overhangs the space between the collar and the hub.
I guess what I'm asking, is there any possible way to drive a steel wedge in between the collar and the wheel?
Sounds like you have a good problem to resolve there!
steve59
08-12-2004 17:22:07
 Re: JD 520 Rear Axle Hubs in reply to Jon C -Florida, 08-12-2004 16:45:43
It is a John Deere 520 and there is not room to get a wedge between the wheel and flange. If there was I could probably cut the bolts also which i think would help as i feel that the bolts are rusted in the wheel more so than the collar threads. Steve
