Duane Larson- Spark Plug?
Clooney
08-12-2004 15:51:40
Duane, can you help me with a spark plug cross ref. or at least shed some light here for me?
I'm setting up a slow running F/M,,T/G engine & have the idle down to well under a 100 RPM.. So as you can guess it goes pretty rich to fire at that RPM..
Presently I am running a Champion 34 plug.. I can get about 2-3 hours run time on that take apart plug before having to clean it.. I have a box of Auto lite 3095 plugs & get way under an hour out of them before they turn to charcoal..
Here�s my question(s): Is there a hotter take apart Champion than that 34? Any idea how the heat range of the 34 compares to that A-L 3095.. Anything hotter in any of the pipe thread plugs with that long extension like the 34..
Thanks-- Clooney
buickanddeere
08-13-2004 08:35:07
 Re: Duane Larson- Spark Plug? in reply to Clooney , 08-12-2004 15:51:40
Alright..... ..... you have us all interested. What do you have there and what are you up to?
Clooney
08-13-2004 09:25:47
 Re: Duane Larson- Spark Plug? in reply to buickanddeere, 08-13-2004 08:35:07
Glen, you"ve heard of Morse code.. It"s engine code..
F-M = Fairbanks Morse.. [small, open crankcase spoked flywheel antique engine]
T/G = throttle governed [uses a type of crude carburetor instead of a mixer & latching exhaust mechanism] � Engine RPM is controlled by a throttle rod to the throttle plate & not by holding the exhaust valve open like H&M engines.. [Oops, that is Hit & Miss]
AB-33 [or AB-34] is small impulse type magneto that uses a trip arm that is usually tripped by a pin on the cam gear.
Getting a F-M ,, T/G [see above] engine to run at less than 100 RPM�s is quite a challenge so takes specific cam timing changes, ignition changes, carb air valve work, good tight [probably hand built] valve to valve guide fit, governor re-work. Hand made throttle plate, lots of playing with intake & exhaust valve spring tensions.. Probably would be about like getting a Deere 2-cylinder to idle at about 100 RPM�s..
Sorry for the cryptic post.. Clooney
buickanddeere
08-13-2004 13:28:21
 Re: Duane Larson- Spark Plug? in reply to Clooney, 08-13-2004 09:25:47
Duane must be one of the very few who knows who you are other than the mysterious but famous "Clooney". We have a family heirloom, a "Monarch" built in Dunnville Ontario. 2-1/2 HP, 500 rpm,gasser, hit and miss with a buzz coil. No hint of a high or low tension mag even being an option. Just a pushrod moving a bolt head into a strip of metal for "points". Can"t find any historical reference either. After the restoration the &^%^& thing tore the calluses off my hand as it kicked back from too much advance when starting. The Father-in-law has a numerous engines in names and sizes I"ve never heard of. Have you tried a slower burning fuel like alcohol? A titanium intake valve? Straight anti-freeze instead of water lets then run warmer. Lower compression, heavier flywheels adding "windage" to the flywheel for some extra drag. Cutting some metal off the sparkplug exposing more porcelain runs hotter too. I didn"t think of souping the mag with modern magnets. Have seen a "Frankenstein" design re-magnetizer made from an old six volt starter used freshen up old magnets.
buickanddeere
08-13-2004 13:27:17
Clooney
08-13-2004 18:05:57
 Re: Duane Larson- Spark Plug? in reply to buickanddeere, 08-13-2004 13:27:17
buickanddeere,,
Quote:
"Have you tried a slower burning fuel like alcohol?" --- Yes, it does slow the burn down a little but takes more spark [that most of the old-timers don't have].. I can't keep them running real slow with much alcohol in the fuel.
"A titanium intake valve?"--- never tried that, I make them out of stainless steel..
"Straight anti-freeze instead of water lets then run warmer." --- I have tried both antifreeze & heavy oils, those engine cool by boiling the water & pure antifreeze allows them to run way too hot.. Most of my old engines have open water hoppers & any antifreeze that splashes out ruins the paint..
�Lower compression,� --- they don�t have much to begin with especially the oil burners. The way I play games with the cam timing they don�t have much left in the cylinder at firing time anyway.. On some I work with the timing & cam timing until they probably have less than a inch or power stroke when firing..
�heavier flywheels adding "windage" to the flywheel for some extra drag.� --- Heavier flywheel would help but is hard to do & ruins the engine original looks.. I have a flat belt drive baker fan for windage if needed..
�Cutting some metal off the sparkplug exposing more porcelain runs hotter too.� --- I�m working with the plug heat range as we speak..
Clooney
buickanddeere
08-14-2004 07:30:43
 Re: Duane Larson- Spark Plug? in reply to Clooney , 08-13-2004 18:05:57
I was thinking in a non working application where low rpms is the primary goal. That oil or 60/40 antifreeze would prevent localized hot spots around the bore & head. For all the heat generated airflow pumped by the back of the piston. And heat radiationing from the engine would disipate enough heat.
Duane Larson
08-12-2004 17:18:55
Clooney,
Well, you have the speed pretty well down there. The hottest 1/2" pipe thread plug Champion made was the 34. I don't recall if it has a glazed nose or not - if the glaze has been abrasively removed the plug will foul quicker.
The Edison 12 is a pipe thread take apart with a very long reach - about half the reach is threaded, and it has 2 ground electrodes, with the center electrode protruding below the shell bottom. I think the reach is longer than the 34, but can't tell for sure. And they are probably hard to find - Don McKinsey lists it as "wanted". I don't recall any other pipe thread take aparts with this long reach.
Splitdorf also made a long reach plug - used in early Waterloo Boy tractors, and that would be another option.
Utilization of the heat range concept started after pipe thread plugs were on the way out, so they are generally not included in heat range charts. Best as I can tell the 3095 is colder than the 34 (which was designed for oil burning engines).
What are you using for an ignition system? Increasing the burn time across the electrodes may help reduce fouling. Cornelius Bergblower used to sell really hot DR buzz coils at Portland - a neighbor used one to mess with the feet/bills of some troublesome woodpeckers.....
If you get to Portland, come by the spark plug display area - there will be a bunch of plugs there of all types and you may spot one that will meet your needs.
Clooney
08-12-2004 18:04:59
 Re: Duane Larson- Spark Plug? in reply to Duane Larson, 08-12-2004 17:18:55
Duane, thanks a bunch, I guess I am about a good as I can be with what's out there then.. You bring up a real good point on the glazing..
Quote: "~Champion made ~ the 34. I don't recall if it has a glazed nose or not - if the glaze has been abrasively removed the plug will foul quicker"..... It sure looks glazed & I have been careful to not use anything abrasive to clean it with.. The plug is old [probably older than me] so I don't know it's history so it's possible it was abused in it's previous life..
Quote: "the 34 (which was designed for oil burning engines)� �.. You do know your plugs,, yes the F-M is an oil burner.. Actually when I show it working a load I use a mixture of 20% gasoline & 80% kerosene & it pulls real nice.. I just can�t use that mixture at under 200 RPM�s no load..
Quote: �What are you using for an ignition system? Increasing the burn time across the electrodes may help reduce fouling��. I wish I had more spark.. problem is: I have the AB 34 mag on that F-M & while that mag does good at very low RPM�s it�s no bolt of lightning.. My other F-M has a F-M rotary mag & it does better at high RPM�s but the bottom drops out of it at very low RPM�s so that AB34 is better at sub 100 RPM�s.. I have a homemade E-coil type buzz set-up that I could probably weld with but it would take a cobbled up trigger & bracket to work on that F-M..
Quote: �If you get to Portland, come by the spark plug display area - there will be a bunch of plugs there of all types and you may spot one that will meet your needs��. I plan on being there [just missed you last year].. I�m not sure what day(s) yet as I�m supposed to fly to Death Valley for some hot weather drivability work about that time..
One more question if I might?� On that 3095 plug.. What do you think of the idea on running a pipe thread die over the threads to move the taper up the plug base a ways so it would seat deeper in the head� I would like it deeper but that could put the base closer to the head so might lower the heat range even more, OR, possibly move the tip farther into the cylinder & away from the head & raise the heat range [your thoughts?]..
Thanks for your time��Clooney
Duane Larson
08-12-2004 19:23:08
 Re: Duane Larson- Spark Plug? in reply to Clooney , 08-12-2004 18:04:59
Clooney,
I'm not sure what would happen if you were to rethread the 3095 - but my guess is not a lot as there isn't enough to take off that would make a difference as I recall. But if you have some cruddy ones - worth a shot and I would be interested in the results.
I have hopped up some AB33's by replacing the magnets as they are old NiCo at the best. I machined pieces of aluminum to the shape of the old magnets, then milled out enough on the backside so I could glue in rare earth magnets from Radio Shack. Painted the aluminum and you would be hard put to see the change. I normally used new coils and condensers also (and sometimes the collector ring), to help reduce internal sparking/breakdown. Far as I know they are still sparking. It did make a noticeable difference. Also try to get the proper edge gap, but that is tricky.
Clooney
08-13-2004 05:35:12
 Re: Duane Larson- Spark Plug? in reply to Duane Larson, 08-12-2004 19:23:08
Duane,
Quote: "I"m not sure what would happen if you were to rethread the 3095 - but my guess is not a lot as there isn"t enough to take off that would make a difference as I recall. But if you have some cruddy ones - worth a shot and I would be interested in the results"..... I have plenty of those 3095"s [I bought a box full for $2.00 a piece].. The ones I have only screw into the F-M head about half way down the threads so I am going to try to run a 1/2 pipe die over a couple [will let you know how it works out]�. I have the access to equipment to instrument the plug body for a temp recording so might do an A/B on standard vs re-threaded� I guess it doesn�t matter as long as they don�t foul as easily..
Quote: �I have hopped up some AB33"s by replacing the magnets as they are old NiCo at the best. I machined pieces of aluminum to the shape of the old magnets, then milled out enough on the backside so I could glue in rare earth magnets from Radio Shack. Painted the aluminum and you would be hard put to see the change��.. That�s a great idea.. I have the machinery to make new end caps for the AB-34 [should be about he same as the AB �33�s you did] & will try either the Rare Earth magnets or some Magna Quench [if I can find a size that fits]..
Quote: �normally used new coils and condensers also (and sometimes the collector ring), to help reduce internal sparking/breakdown. Far as I know they are still sparking. It did make a noticeable difference. Also try to get the proper edge gap, but that is tricky��. I have been having problems finding parts for the AB-34 [I�ll talk with you at Portland about that] .. On the edge gap? I have been playing with that & it�s basically a trial & error but it still might be off a little as the spark is pretty weak [lucky to get 1/8�-3/16� cold].. The spark seems better on the bench than on the engine so I probably have some resistance between the cylinder head/crankcase/mag bracket/mag body� That AB-34 sure doesn�t like ANY resistance in the secondary [even dirty plug threads seem to count against the spark].
Maybe you can give me some tricks on getting that edge gap set better at Portland..
Thanks for the chat�. Clooney
Duane Larson
08-13-2004 08:03:14
 Re: Duane Larson- Spark Plug? in reply to Clooney, 08-13-2004 05:35:12
Clooney,
Anytime. See you at Portland. We'll be there Monday till Saturday, with base camp at spark plug display.
Regards,
Duane
