Henry, Im gonna try n dig out some of my old motor manuals n catalog data later tonight from my old engineering days at Century Electric Motor Co (circa 1970) if I can locate it, cuz I did have a lot of that old info saved which may include some color codes etc. I wasnt at that position too long before I got into electronics (nuttin to do with motors) but then got back to Secondary Power Distribution prior to my retirement. I really really wished one of those wires had been white as I would have guessed that as a neutral. Having no idea as to what you actually have, about the only way I would know to proceed would be to use your ohmmeter and measure the resistance between some of those leads. I think I would start by guessing (just a guess mind you)the red as one of the main feeds with others maybe having different resistance values to the red as different RPM windings. As I instructed below, try the highest resistance combination of leads (L1 & L2) first (between 2 particular wires) and try a current limited voltage flash test to see if she attempts to rotate. The problem is, the ballast may drop too much voltage to allow the motor to try n rotate?? If so, then lessen the ballast and try another flash test. If nuttin happens, dont leave the power applied too long or you may fry a winding and DO NOT apply votage to any lead combinations that have extremely low resistance betwen them. If you can isolate a common wire that has diferent resistance values to it and they all are connected to it, that would be my guess as L1. Use caution n common sense and dont apply 120 VAC to any low resistances and you may be able to finger her out enough to get her to run at one speed at least if shes a multi speed motor. I apologize we cant give definitive answers to these questions, but not knowing what you have and with no data or manuals or diagrams etc., about all we got to go on is some basics and try n figure it out from there. Good Luck n God Bless, I will post back if I locate that data and you do likewise if you can come up with any make model or serial numbers etc. John T
