Anybody using 2 cyls to farm
mik
08-12-2004 12:17:29
Is anyone still using 2 cylinder JD's as primary farm tractors? If so, which ones, and how are they working out? Advantages, disadvantages?
Carl
08-18-2004 12:41:04
 Re: Anybody using 2 cyls to farm in reply to mik, 08-12-2004 12:17:29
My father-in-law had a small hog operation with 80 acres planted in corn 1n the late 1970s. He had a IH Farmall 560 with M&W turbo kit to plow and disc, but he planted, cultivated, and picked the 80 acres with a JD 520.
bent
08-13-2004 07:55:03
I use an AR, 60std and 730stdDES to maintain the yard, run haybine, rakes and small square baler on about 140 acres. I put up 1,000 - 1,500 bales a year, sometimes do a bit of custom work with land leveller.
Jericho
08-12-2004 17:40:14
We still use the 2 60's EVERY day. One for hauling sh!t, and one for green-chopping. Also use a 730D, 2 B's, and an A quite often, especially during haying season. Couple weeks ago we raked about 40 acres with the A and both B's. Now THAT was cool! Anything that doesn't get done by the 2-cylinders is done by the 3020D. Have a 4520, but only use it for plowing usually.
John Van Valkenburgh
08-12-2004 17:06:26
I use my model 50 most every weekend around the horse farm I live on. Perhaps not "farming" in the traditional sense, but it keeps the pastures mowed by running an estate mower. Drags the riding ring with a tine harrow, drags the pastures in the winter using a chain drag to break up the manure piles. Pulls a road blade with a lot better traction than the "new" tractor.
Is that farming? Depends on your perspective. I think of it as farming but not full time like the real boys. I've seen real farmers and they earned my respect at an early age. When I was just a kid of 5 years or so I remember the local dairy farmer using his model 50 for plowing gardens and haying, hence my attraction to the 50.
Even though I'm not running the equipment on a daily basis I will say this, the 50 isn't just a toy. It earns its keep. For the money I've put into it, you can't beat it. I bought it for $2400 a couple of years ago and have put maybe $1500 into it (including new tires all around for $800). There isn't a new machine I can buy for $3900 that could come close to it's durability.
I think most "tractor" people have a favorite. For some it's their 8N, or Massey 135. For me it's definitely the 50.
John
1953 Model 50
wyodave
08-12-2004 16:56:21
Although not our primary tractors by any means we still use a JD 70D to bale with about 4 hours a day 5-6days a week when we're cutting hay. We also have a 720D and a 620 and 630 we use to do small jobs so we don't have to unhook all our haying equipment. We have and entire barn full of JD two cylinders though and we try to get them out once in awhile. 2 D's, 2 A's, 3 B's, a G, a H, a 60, 70, 620, 630, and 720. My grandfather was a mechanic for JD during the two cylinder era and when he retired from farming he made a good collection and we still keep them around. The best part of the old tractors is how cheap they run. The 70D on a JD 348 baler will burn half the fuel a JD 4040 and 348 burns covering the same ground. Major disadvantage is operator comfort.
DY
08-12-2004 15:59:18
I was using a JD 60 until about an hour ago. For the most part it works great but I am just a hobby farmer.
thurlow
08-12-2004 14:44:35
Mike Hanley uses 4 or 5 two-cylinder tractors to farm with; think he has some serious health problems; hasn't been on here in a while. Anybody heard from him???
Brian Brud
08-12-2004 14:17:46
I am sure trying! Equipment is the biggest problem, if you can scrounge abit and find each little piece in good condition I hope it can be done. My problem is going backwards in equipment, when you are used to a 5-18 plow with auto reset and hi clearance, it's really hard to unplug a 3-14's plow that shoouldn't have plugged in the first place. The key to farming 160 acres in Iowa with 2 cyl. was livestock. If you had 40 acres in hay 30 acres in oats, 20 acres of pasture, the balance in corn didn't seem so bad.
buickanddeere
08-12-2004 13:55:06
70D or 720D on the 1219 mower conditioner, stone windrower and seed drill. 70G for hand picking stones and pulling the harrows/packer. the 40,50's,60,70G for hauling fire wood from in the bush and the wagon up to the buildings. 80 has pulled the cultivator when the 4050 had a hydraulic line under the cab leak during spring tillage. 435 runs a smal snowblower and scraper blade. Wished it had power steering so the model 35,36 or 37 loader in the barn could be mounted. The 2355 does mostly loader work now and where slow backing up is required. The utility tractors did the light work until the two cylinder collection grew and need something to do. The 4050 ploughs,cultivates, mechanicaly picks stones,round bales and blows snow. As far as serious farming and not having modern tractors in reserve and on specialized equipment. Wouldn't consider trying to farm with only old worn out, failure prone equipment.
Mike M
08-12-2004 13:05:57
I used to do some work for a local dairy farmer all he has are two 620's and a 3010 diesel. He just sold his farm and is retireing I keep watching for a farm sale these should bring good money as he keep his equipment in good shape. Advantages were they are paid for so you don't need to farm as many acres to pay the bills. Where I live still many using just horses. Northeast Ohio lots of Amish buying up the farms.
Joe P.
08-13-2004 04:47:46
 Re: Anybody using 2 cyls to farm in reply to Mike M, 08-12-2004 13:05:57
Hey, I am also in Northeast Ohio. Where is that guy with the tractors so I can watch for the sale too :)
Mike M
08-13-2004 08:39:14
 Re: Anybody using 2 cyls to farm in reply to Joe P., 08-13-2004 04:47:46
In Wooster Ohio it may be a Orrville address His last name is Gresser I haven't talked to him to see if he is haveing a sale but I know the people that bought his farm and they said he was.
