530 fuel tank
draire
08-12-2004 06:53:32
Does the fuel tank on a 30 Series have an overflow to account for gas expansion from heat? I've noticed that when I fill the tank nearly full I leak a fair amount of gas onto the Power-Trol pump when elevating the front (such as loading onto the trailer).
The spill does not occur when the tank is half full or less.
Is there supposed to be a rubber hose attached to an overflow tube that would drain to the ground if attached?
Where can I determine what the fuel tank looks like w/o taking the cowling off? Anyone have a picture?
There is nothing in my Service manual
Any help/advice would be appreciated.
Thanks!
Mike M
08-12-2004 09:58:38
 Re: 530 fuel tank in reply to draire, 08-12-2004 06:53:32
You will have to pull the hood off and check the vent pipe doesn't have a hole in it and check to see if the gauge sender unit isn't leaking. My cousins 520 did this very same thing and he had a leaky sender gasket.
draire
08-12-2004 12:54:59
 Re: 530 fuel tank in reply to Mike M, 08-12-2004 09:58:38
Thanks.
My Fuel Gauge does not work and I suspect the Sending Unit. So, once I can find, and install, a replacement, along with a new gasket I should fix the leak if it is as you suspect.
What is the correct way to test the sending unit?
What voltage do I put acoss the fuel gauge to test it?
Can I get to the Sending Unit by removing the dash instead of removing the sheetmetal?
Mike M
08-12-2004 13:18:28
 Re: 530 fuel tank in reply to draire, 08-12-2004 12:54:59
The hood has to come off. Take the grille off then unbolt the hood and lift it off on the 30 series the gas tank stays with the tractor. You can test the sender with an ohm meter I don't know what the values are I just see if it has contiuity that varies across the range of movement. Then I test it together with the gauge. Hook it up with test leads just like it is to be in the tractor to a 12 volt battery.Don't forget to ground both pieces. I have seen some aftermarket senders and gauges that would fit and work but they don't look original and they are neg. ground so you would have to switch your tractor over.
Clooney
08-12-2004 07:18:30
draire, there should be a vent line running from the top of the tank to the L/H radiator area.. If that is plugged it will cause a pressure build up.
On your leaking fuel towards the rear when lifting the tractor front- suspect a leaking [or incorrect] fuel filler cap.. Those later vented fuel tanks don�t have a filler baffle down in the filler neck area so when the tank is full [or nearly full] fuel can leak from the filler cap area then run down the tank lower edge & to the rear..
Make sure your filler cap is the later NON vented cap & the gasket is in good shape.
[email protected]
