JD 425 Transaxle Trouble
Mikekar
08-11-2004 19:26:20
I have a JD 425 2WS garden tractor I bought at an auction. I runs good for roughly 15-20 mins then the transaxle seems to loose power and won"t go up even a slight incline. Any clue if this is a fixable issue or if the entire transaxle needs replaced? From what I can find it has a Kanzaki transaxle in it.
S. Conner
08-13-2004 08:27:16
 Re: JD 425 Transaxle Trouble in reply to Mikekar, 08-11-2004 19:26:20
I've got a 455 that has the same transaxle but fortunately I haven't had a bit of trouble with it. The first thing I would do is change the fluid and filter if you haven't already. Be sure and use the low-viscosity hygard oil from John Deere. It's about $11 a gallon but worth the money. My service manual isn't here to look at but I think there is a troubleshooting section in there. Sounds like it could be the relief valve for the charge pump letting go when everything starts to get hot. I'll check my manual if I can find it.
R. Rivard
04-04-2006 10:23:51
 Re: JD 425 Transaxle Trouble in reply to S. Conner, 08-13-2004 08:27:16
Could someone please send me some info on where to find a John Deere 455 Transaxle or maybe someone who has one that wants to get rid of. Ours is toast, we got it that way. The people who serviced it didn't refill the fluids and it was run for a while and they didn't realize it in time. The mower is in good shape but needs a Transaxle. We can't seem to find anything on it. We don't even have a book on it. Any info would be greatly appreciated. Thanks, Rick.
mikekar
08-14-2004 07:08:35
I have changed fluid and filter, no help. I can"t find any information in my owner"s manual on the hydraulic system. It only has "how to change the fluid and filter". Let me know if you have any information on the hydraulic system (charge pump, relief valve(s), relief valve settings, etc.) or direct me to someone who might have information. Thanks!!
Mike M
08-12-2004 13:24:02
You could always fix it like the last owner did.
Take it to an auction and sell it. It will run and move great for the quick demo before the sale.
I'm sorry to hear you got burnt. I don't like buying at auctions too risky as most stuff brings top dollar,once in awhile you get a deal.
Henry J
08-12-2004 07:00:41
Mike
This is a shot in the dark. If that transaxel is the blet driven type, I would first check that the drive belt is up to the chore. It is common to find that the belt tensioner has rusted up on the pivot and the belt doesn't have tension on it anymore, or it is shot to start with.
Mikekar
08-12-2004 18:11:55
 Re: JD 425 Transaxle Trouble in reply to Henry J, 08-12-2004 07:00:41
Unfortunatly it"s not belt driven. Any other guesses?
leon
08-12-2004 03:53:30
How have you determined that the trouble is in the transaxle rather than in the engine? Perhaps it's the engine losing power.
mikekar
08-12-2004 18:16:51
 Re: JD 425 Transaxle Trouble in reply to leon, 08-12-2004 03:53:30
The mower deck is direct driven off of the transaxle. The steering is hydraulic power steering. When I mow with it the engine is running just fine and after about 15 -20 mins turn the steering wheel makes the tractor slow down the mower will bog downevenin lightgrass and the tractor doesn"t want to even go up the slightest incline. All the time the engine is still purring along like a champ. Still stumped??
iniscuis
04-28-2005 03:12:16
 Re: JD 425 Transaxle Trouble in reply to mikekar, 08-12-2004 18:16:51
Sounds like the clutch pak in the transmission is worn. you can buy the clutch plates from JD and rcondition the unit.
iniscuis
04-28-2005 03:25:20
 Re: JD 425 Transaxle Trouble in reply to iniscuis, 04-28-2005 03:12:16
Has anyone had a problem with the hydrostatic transmission failing? usually the shaft running the differential breaks down. anyone know where to source one of these?
thanks
